Posted (edited) · Printer head too high
So I'm trying to print with cura on the worst printer on the world XYZ printing da Vinci Nano (It was a gift and no i don't have money for better printer). And the problem I'm trying to fix is that my printer nozzle is about 4.35 mm above the bed. I logicaly tried to rise the bed and manually level it but I can't lift the bed that much. In original software there is a thing z offset set to that -4.35 mm. I tried that addon on the marketplace "Z offset" but highest value I can set there is -0.44 mm. So my question is there somewhere setting that could help me? Also printer settings are exactly as on this guide https://xyzofficialweb.blob.core.windows.net/xyz-v3/download/Cura_Profile_XYZ.PDF(Also attached image)
* EDIT:
Also only thing in printer settings I wasn't able to set is "X min" it would always set back to -20 when I change it lower. I don't really thing that should be it but just in case.
** EDIT:
I've managed to fix it but I don't know why.
Edited by maruskaa
          • Heart
        • 7 replies
