The export settings in a PDF (sorta annoying) and gcode themselves aren't enough troubleshoot with, if you could provide the project file (,3mf, get to the point before you'd save the gcode and go File > Save Project) as it contains the slicing settings without having to go side by side with the PDF and Cura, and ideally the STL file of the model that would help greatly.
You seem to have the "Spiralize Outer Contour" option on, which needs to be turned off. You will also need to check the "Remove all holes" setting, which also needs to be turned off.
Slashee_the_Cow 382
