A link to one of many of Joris' cool cups with z movement:
https://www.thingiverse.com/thing:75735
Note how the color moves up and down as it goes around. Because the Z axis was moving as it goes around. He did this in some kind of post processor plugin in the old Cura back in 2013.
gr5 2,190
It seems your Z axis is moving even on a single layer. Very strange. Did you really reslice an STL from scratch?
Okay so why is the Z axis moving...
1) It moves on the S3/S5/S7/UM3 for level compensation but the UM2 series printers don't have that feature. And it only does it on the bottom 5mm or so.
2) Maybe there is a plugin that added some tilt to the cup? Joris created a cup per week for a year (52 cups) and a whole bunch of them have Z movements. On purpose. Because it creates a cool pattern. The Z movements increase more and more as you get higher up the cup.
That's all I can think of. So I'm not surprised that the gcode of a cup has Z movements on a given layer. But if you reslice an STL in Cura the Z axis movesments should go away. Do you have the STL file of the cup? I'm thinking maybe not and you loaded the gcode into cura and then "resliced" but you can't slice gcode - you can only slice STL files.
