What printer do you have? I'm pretty sure this requires one with dual extruders.
Cuq,
Thanks for your response. Would it be possible for you to send me your .3mf file?
How have you set up Cura so that it knows you have different materials in each extruder?
- Solution
Slashee, CUQ
Thanks for your responses. I figured it out. If you have your "Color Scheme" in Preview set to "Line Type", it does not separate colors by material. If you change it to "Material Color", then it shows what I was expecting to see. So it was working all along, I just needed a different point of view. 🙂
Again, Thanks!
Cuq 208
With version 5.5, there doesn't seem to be any particular problem.
