37 minutes ago, GregValiant said:That's the basic boilerplate StartUp Gcode. There isn't anything in there that would cause a problem. Cura adds a prepend before that section in the gcode and the prepend has the starting temperature commands in it.
Printing over the USB can be very glitchy. Try printing from the SD card and see if the problem occurs that way as well.
You can open the Gcode file in any text editor and search for M104 and M109. You may find an M104 at the end of Layer:0 and it will be M104 S200 (or whatever your print temperature is). You can also search for M140 but I'm sure the only one will be at the end of the file in your Ending Gcode.
This problem has happened with other printers but I can't remember if they were Longers or another brand. A search of the forum might bring up posts about the problem. You could zip and post the gcode here but the problem is likely with the printer.
after layer 0 at the actual start it just says this
;LAYER_COUNT:160
;LAYER:0
M107
;MESH:3DBenchy.stl
G0 F7500 X127.771 Y151.43 Z0.2
is it that i just need to type in M104 S200 and M190 S60 after to fix it?
GregValiant 1,260
