- Solution
GregValiant 1,259
Turn on the "Custom" settings. Under "Build Plate Adhesion" will be "Build Plate Adhesion Type". The options are Skirt, Brim, Raft and None. When set to "None" you shouldn't get a skirt.
You can also set the number of laps of a skirt. The default is 3 laps but you can set that to 1.
msculenny 0
Also this is my first post ever so apologies if I didn't pick the correct topic description.
