Suddenly, the left build plate guiding rod seems marginally misalligned, creating loud noise during leveling (Ultimaker 5s)
Posted
· Suddenly, the left build plate guiding rod seems marginally misalligned, creating loud noise during leveling (Ultimaker 5s)
Sounds like the machine is cold. Without running a print, try setting the bed temp to 60 degrees and leaving it to warm up for 20min or so then try again.
Posted
If that is miss aligned suddenly.. it sounds like the frame of the machine itself has suffered impact or excessive pressure and pushed it out of square.
mrender 25
