Doing a quick rapid hyperspeed scroll through the gcode, it's all in positive co-ordinates and not past the bounds of your printable area.
The first thing that comes to mind is to go into your printer's settings in Cura and turn on Origin at center and do a quick test print. I'm not sure what the right setting for your printer is, but if you centre the thing (really, you could just make like a small cube or something, we're just testing positioning here) in Cura and see where it prints you can know for sure which setting is correct.
The test prints you did: did you slice them yourself or just get them as gcode? If it's the latter, if you could upload the code for one, can see if anything looks vastly different to your slice.
Slashee_the_Cow 279
Could you upload the 3mf project file (in Cura, go to File > Save Project) for this so we can compare the gcode to Cura's settings?
