https://makerworld.com/en/models/69150#profileId-73407 i one example but any .3mf file does the same thing and attached is the only file named cura in that folder
I can't really see anything wrong in the log file - unfortunately when there's no visible culprit the first resort is the software version of "turn it off then on again" - a clean reinstall. There's instructions for it in this support article. Just make sure you download a fresh copy instead of running the installer you have because the download may have been corrupted.
- 3 months later...
is there an update to this issue?
I've got the same problem "No Model in file" and it is also a file from makerworld.
Regards
3 hours ago, Breuer-IT said:it is also a file from makerworld.
It's possible their 3mf files are somehow incorrectly formatted - 3MF is an open source standard and Cura shouldn't have any trouble reading valid files (the format supports features Cura doesn't have, but Cura just ignores them).
Hi Everyone.
I too am having some problems opening a .3mf file - but this one is from makerworld. Here is a link to it: https://makerworld.com/en/models/71322#profileId-75511
Here's the error I get
I even tried downloading Prusa slicer (v2.7.2 is the latest at the time of this post), that couldn't open it either (says the 3mf file is corrupt). I then went to SwiftConverter (https://www.swiftconverter.com/converter.html?threed) which then converted the .3mf to a STL for me, but I only got the top part and no rear lid. I googled some more and found this
where OP claims he can't open the 3mf in 5.3.0 but can do in older versions. So I downloaded & installed v 5.2.0, and that couldn't open it either.
Edit, oops, ended up posting this before I finished my reply.
In the end what I had to do is download and install Bambu Studio, then open the .3mf there (worked successfully) and then went to file -> export -> all models as STL
Now I can and open & print in Cura.
Edit 2: You can actually go to file -> export -> generic 3mf, and that will now open in Cura (and presumably other slicers too). Looks like in typical fashion Bambu 3mfs don't open in other slicers.
Edited by SamPilgrimsTooth- 1
@SamPilgrimsTooth Awesome investigation work there.
2 hours ago, SamPilgrimsTooth said:Edit 2: You can actually go to file -> export -> generic 3mf, and that will now open in Cura (and presumably other slicers too). Looks like in typical fashion Bambu 3mfs don't open in other slicers.
Fun fact that explains a lot: Bambu was started by a group of engineers who worked at Apple.
- 1
Actually most of them worked for DJI
- 1
16 hours ago, Dustin said:Actually most of them worked for DJI
It only takes one bad Apple to spoil the bunch.
- 1
- 4 weeks later...
Same problem here, No models in file when trying to open a 3mf from Makerworld
5 hours ago, X-Type said:Same problem here, No models in file when trying to open a 3mf from Makerworld
Please post the file or a link to it, but as discussed above it may be a problem with the file itself rather than Cura.
Slashee_the_Cow 277
Could you please go to your Cura configuration directory (in Cura, go to File > Show Configuration Folder) and upload the cura.log file?
Also if you could provide a sample or two of 3mf files which don't work that would help.
