CuraEngine - Trying to execute from PYthon Shell....
Why you have to put the single quotes around it: Because the shell command you're entering contains quotes. The command is a string in Python so putting the same type of quote you start with in the middle of the string will end it. But you can put " in a string contained by ' and vice versa.
Why you need the r: Technically you don't. r before a string will make Python treat it as raw text. Normally a backslash \is treated as the start of an escape sequence, like how \n is a new line. You can avoid this by using double backslashes (which just get converted to a single backslash), just make sure it's not a raw string if you do: os.system('"D:\\Program Files\\UltiMaker Cura 5.5.0\\CuraEngine.exe" -v')
Edited by Slashee_the_Cow
Slashee_the_Cow 272
The quotes need to go around the path to the program, but not the arguments (unless they contain spaces)
So it should be:
