2 hours ago, Slashee_the_Cow said:What do you have selected for Travel > Combing Mode? At the very least it should be set to Not on Outer Surface (though as a bit paranoid myself I have it set to Not in Skin).
Although it sounds like the problem might be the end gcode, which isn't going to be affected by combing settings. You could try adding this to your end gcode, before everything else: (Tried to think of a non-confusing way to say "start of end gcode" and probably failed miserably)
G91 ; relative positioning G0 Z5 ; get 5mm vertical clearance G90 ; back to absolute positioning
Thanks i will try this in my next print! sounds like the answer!
Slashee_the_Cow 272
