En CURA defino los parámetros de porcentaje de relleno, Adherencia, etc. y mi impresora Ender 3 V2 los cumple, pero otros como la velocidad y temperatura de capa inicial debo seleccionarlos desde el comando manual de la impresora. Tengo algún parámetro deseleccionado? Gracias
GregValiant 1,488
The temperatures should be handled by your StartUp Gcode. If there are no temperatures in the machine startup then Cura should add them before the StartUp section of the gcode.
Open the gcode file in a text editor and just under the "Generated with..." line should be M104 Sxxx for the nozzle, M140 Sxx for the bed, and maybe M109 and M190.
Go to Settings, Printers, Manage Printers, Machine Settings. In the lower left text box is your startup gode. Copy that and you can paste it in here.
Dustin 193
UltiMaker has had no affiliation with Youmagine since 2017.
You can read more about that on their own blog: https://blog.youmagine.com/2022/05/a-new-phase-for-youmagine/
