In regards to cooling I'd say that if you typically print the material with cooling then the temp tower should be with cooling. The fans (and you have serious fans) are going to effect the hot end temperature.
It's hard to tell in those images but it appears there may be some under-extrusion going on.
GregValiant 1,253
