Multiply .3mf object and reload failed in CURA 5.6
Posted
(edited)
· Multiply .3mf object and reload failed in CURA 5.6
That is normal behaviour. The copies aren't linked to the the original. If you install the Mesh Tools plugin that allows you to right click an object and replace it with a new mesh (in this case, load the same file again).
Edited by Slashee_the_Cow added info about plugin
1
Slashee_the_Cow 267
Edited by Slashee_the_Cowadded info about plugin
