Posted
· Nozzle doesn't seem to retract between layers
If you could share the Cura project file (.3mf, in Cura get your file ready to print then go to File > Save Project) that would help. In the gcode file it's definitely retracting 1mm at 40mm/s before each layer change.
But from I can find the Flashforge Adventurer 4 uses a Bowden extruder - they need a much further retraction than a printer with a direct drive extruder. I found with my Ender-3 v2 Neo that I needed 5-6mm retractions for PLA or up to 8mm for more stretchy filaments (like PETG or TPU).
Slashee_the_Cow 276
