An update in the backend of the Ultimaker Marketplace has caused an issue with who gets to "see" all plugins (regardless of the type of account being an Essentials/enterprise account).
The workaround is to log out of your account inside Cura, and then go to the Marketplace inside Cura. You can install the plugin(s) you want without being logged in via the Marketplace dialog in Cura. Then, when you have installed the plugin(s), you can decide if you want to log in again.
Edited by ahoeben
- 1
Slashee_the_Cow 276
Are you logged in to an UltiMaker account? A lot of business accounts have restrictions on what plugins they can download and it's not uncommon to have your email address accidentally flagged as belonging to one. If you are logged into an account, try logging out and see if you can see it in the marketplace then.
Also: some plugins have minimum versions of Cura required. If you're running an older version, it might not support it.
