Cura 14.03 - no temperature setting any more for Ultimaker 2?
Posted · Cura 14.03 - no temperature setting any more for Ultimaker 2?
Just tried the new version of Cura 14.03 on a Mac. I realized that the field for setting the temperature has gone if you have an Ultimaker 2. If you select the Ultimaker 1 the temperature field is still there. Is this a bug or why has it been removed?
    None of the Cura's with Ultimaker 2 support allowed you to set the temperature for those machines. The temperature is set directly in the printer, not via the gcode.
    Can you try also with machine settings change the GCode Flavor to RepRap, then there are many more configuration options including Temps. The UM2 can therefore work in any case, no idea if there are disadvantages.
    But I know the Mac version of Cura not, perhaps there are differences.
    Markus
    Thanks @illuminarti. Too funny, didn't realize that in the previous version... All right, "issue" solved :cool:
