Estimating Length of Filament Remaining
Go to solution Solved by dan_bruton,
Posted · Estimating Length of Filament Remaining
I love this.  I looked at your spreadsheet.  I have a problem with it as it's "access only" so I can't change the PLA Diameter to 2.85mm (which is what Ultimaker uses).  And ideally the radius and width would default to Ultimaker spool dimensions.  I also love how you show your assumptions on the spreadsheet itself (but not in the image above).
I moved this out of the ultimaker printer area and into "3rd party...".
Is there a way you can allow people to edit the 3 yellow blocks only?  Or create this as a javascript web page?
But I do love this and hope to be able to use it some day.
  • 1 month later...
  • Solution
@gr5  Thanks!
Oh, yeah.  Note that you can select “File” and “Make a Copy” for this Google Sheet once you login to your Google Account.
This will allows you to edit the document and keep a copy for yourself as well.
Hope this helps!
Dan
