Ok I understand that... Ty for the explanation
But if I remember correctly (I would have to reinstall the old Geeetech to be sure), the nozzle setting had a direct influence on the chosen profile and adjusted some settings. That's not the case here anymore... Correct?
Or asked the other way around:
Is there a way to restore the dropdown manually? I only use 4 different nozzle sizes, but mainly just two. So it was extremely practical and you couldn't forget it because it caught your eye when choosing the material...
ahoeben 1,951
The Custom FFF Printer doesn't have a nozzle size dropdown. Instead, you configure the nozzle size in Preferences -> Printers -> Machine Settings -> Extruder. It actually does give you more freedom than printers that have a dropdown for the nozzle size, since you can enter any size you want (instead of being limited to just a few).
