18 hours ago, Slashee_the_Cow said:You can do it with a post-processor. If you go to Extensions > Post Processing > Modify G-Code that'll bring up a window with a dropdown box on the left. I have so many scripts installed I can't remember what actually comes with Cura, but there should be one something along the lines of "Display Info on LCD". If you have that one you can either set the top option to "Filename and Layer" so if you can remember what layer your change is on then you can use that. Or I think if you set it to "Display Progress" there's an option to replace the time to completion with the time to next pause.
Yah, 'Pause at Heigh' script, then select 'Layer' will do it! Cheers.
Edited by ShuttleSpaceTo add and clarify detail
Slashee_the_Cow 620
