Posted
· Ultimaker Cura generates no infill [Solved]
You have Special Modes > Spiralize Outer Contour turned on. That will only draw a single line around, going up slowly, so that there is no Z seam, but it can only be as wide as a single line.
Although your current settings won't generate infill anyway; your walls are so thick that they fill the entire space:
Slashee_the_Cow 295
Turbomichi 0
Thanks Slashee_the_Cow. That solved my problem.
Your help is really appreciated.🙏
