- Solution
-Add a support blocker block
-Go to "Per model settings"
-Set it to "Modify settings for Overlaps"
-In the drop-down menu below it, set it to "Cutting Mesh"
-In the bottom left corner, while having your "support blocker" block still selected, select your second extruder
-Scale the "support blocker" to your required size, and set it to your required X/Y/Z
That should print everything in the area you marked with your 2nd extruder.
I call it a "support blocker" because it loses that functionality if you set it like this in the per-model settings.
Slashee_the_Cow 271
I'm not fortunate enough to have a multi-extruder printer so I'm sorry I can't be more help. But I do know that if nothing else, you could manually edit the gcode to do it.
