Problem with a print / stringing with small figures / bed adhesion? Picture below
GregValiant 1,345
The "Wall Ordering" setting is in the Wall section. You can try "outside to inside".
There seems to be a couple of problems. Have you tried using an adhesion promoter? Is the bed nice and clean and wiped down with Isopropyl Alcohol?
If you increase the "Initial Layer Flow" by 5% you will get more squish.
Enabling Z-hops can either fix the problem, or make it worse (if "not sticking" is the issue).
What is your Initial Layer Print Speed? A slow first layer would seem to be a good idea.
There are a lot of hearts with tips missing. Something might be going on with the retraction settings.
