If you could provide a Cura project file (.3mf, in Cura get it ready to print then go to File > Save Project) that would so we can see your slicing settings and such.
I don't know about the file from Thingiverse but the problem with the STL you uploaded is that that base stops, then the cone starts - they have pretty much no connection to each other. You need to extend the cone down into into the base so that it's being joined in with it. Also bear in mind that something just a couple of walls thick is going to be inherently fairly weak, especially where it goes from being "solid object to" to "couple of walls", so I'd increase the thickness of the cone if possible.
1
Slashee_the_Cow 269
