Hmmm... Ok.
This means that the flow rate setting in CURA is converted to the extrusion rate and does not appear as M221 in the gcode... Did I understand that correctly?
This also means that the print server doesn't notice anything and the flow rate set in the print server of, for example, 100% represents the flow rate of, for example, 90% converted into CURA... Correct?
The slicer flow rate settings are often ignored / notr in gcode
- Solution
A print server won't notice the difference, it's just sending the code Cura creates. If your server is set to 100% flow rate then it shouldn't touch the values Cura has calculated, so if you had 100% on the server and 90% in Cura, it will go at 90%.
Are there any settings/circumstances in CURA that still allow an M221 to be integrated into the gcode? Because occasionally when the gcode is transferred from CURA to the server, the previously set 100% on the server is changed. I just haven't been able to figure out in what context and why...
50 minutes ago, CBX_Micha said:Are there any settings/circumstances in CURA that still allow an M221 to be integrated into the gcode?
It could be changed by a post-processing script, and often startup gcode will contain "M221 S100" to make sure the flow rate is set to 100%, but I just searched literally all my gcode files (gotta love Notepad++) and those are the only instances of M221, never in anything generated by Cura itself.
Unfortunately I'm not familiar with your server software so I wouldn't know of any other reasons why it could do that.
The flow as entered in the materials category of the settings is never put in the gcode as a M221 command by Cura. Instead this setting is used to calculate the E steps in extruding moves.
The "Tweak at Z" post processing script may be used to insert M221 commands in the gcode at certain heights/layers. This command acts as a "multiplier" on top of the flow as entered in the materials category.
Edited by ahoeben
Slashee_the_Cow 272
You don't have to use the M221 command to set flow rate - you just calculate it the extruder position.
Try making some gcode with flow rate changes, and then one that's 100%, and see what the E value is in the last G1 move on the first layer.
All that M221 does is do those calculations for you.
Edited by Slashee_the_CowLink to post
