Hey bud, thanks for the input.
Nozzle temp is 145 deg.
Yes it is a bowden extruder but it is running an all metal hotend so if you use 6mm retract you will get a blockage. I used to use 6mm on the standard hotend. Hotend manufacturer specifies less than 5mm for retract.
Yes it is dry - spent 9 hrs in the dryer before printing.
I've also cleaned hotend without improvement.
I've attached the file
The issue starts at the seam. When the nozzle travels to the seam and when it starts to move is when is doesn't extrude.
Edited by sketchy984
Slashee_the_Cow 271
It's really hard to tell just based on a couple of photos - if you could upload your Cura project file (.3mf, in Cura get it read to print then go to File > Save Project) that would help a lot.
The three things that first come to mind are:
