Thanks for chiming in. I did just that and I'm testing currently.
Is there a way to extract pure text printer definition out of a 3mf project file? If so, one would be able to just feed it to
https://github.com/Ultimaker/Cura/wiki/Definition-Files-Explained
Slashee_the_Cow 274
I just tried making the configuration file for my machine instance read only, and that just made Cura crash when I tried changing any of the settings.
Try making a new instance of your printer (add it again through the add printer wizard), make the changes on that, and use it. Hopefully older projects will open in the original instance then you can just switch to the new one, and it should keep the quality profiles as they'd be based on the same definition, but not transfer the settings. I think.
An option to save .3mf files with only the necessary quality profile changes to print it properly (and/or a "guest mode" where it doesn't make any permanent changes when you load a file, which would be awesome for us on the forum testing things) has been discussed but I don't know if it's currently in active development. You could try submitting a feature request for your specific situation and see what the developers have to say about it.
I have the same sort of problem... all my older projects are saved with a typo in the head size which triggers a bug where the head is shown as a parallelogram if you put it in "one at a time" print mode. Whenever I load an older project, I have to go into the machine settings, click in the box for each of the print head sizes, then select another box (any one) to get it to save it the correct way.
