Thanks for pointing out the measurement error, very large print ;-}.
Plane Print recommends using version 4.13.1, not the newer versions. Probably all the testing was done with this version
The tool path does not change with Spiralized checked
Happens at the z seam start
Normal PLA, due to stringing I'm having to play with the retraction settings, too much then I'm getting holes, too little then more stringing.
I've tried Extra Retraction Prime at different values with no change. Is this setting not the same as normal retraction?
thanks for the response, greatly appreciated.
Steve
Slashee_the_Cow 269
I'm going to assume that's a typo and that the problem doesn't take nearly a metre to correct itself.
If you're printing single wall though: why aren't you using spiralise mode? (Special Modes > Spiralize Outer Contour) - no Z seams whatsoever. Or am I misunderstanding things and it has guts but only one wall around the outside?
Also:
If it's becoming too thick then the problem is probably overextrusion from something. Have you tried without the extra retraction prime? That will result in overextrusion because it extrudes further than it retracted (to make sure there's sufficient pressure in the nozzle to start printing again).
