@Slashee_the_Cow Absolutely correct; that fixes it. Dumb typo on my part! Thanks for your help.
But, in my definition, I have
"machine_max_feedrate_z": { "default_value": 2 },
and without the speed_z_hop line in my definition, Cura puts 10 for speed_z_hop and seems to disregard the "maximum_value" setting. Perhaps fdmprinter's default value should be machine_max_feedrate_z? I guess Cura doesn't check a value against the max or min values unless a user types in a number.
I find that if I put
"speed_z_hop": {"default_value": machine_max_feedrate_z},
in my definition, z hop speed is set correctly, and this lets the default value track my printer's actual z feed rate.
Slashee_the_Cow 344
In my definition, I have
"speed_z_hop": {"default<needs to be underscore instead of space>value": 2},
