1 hour ago, ahoeben said:The USB support in Cura is not actively maintained, and hasn't been for man years. If it works it works, if it doesn't work it doesn't work. Period. You can be uninterested in the following advice, but it is all you are going to get.
Your best bet if you want to continue printing over USB is to install OctoPrint (either on the same computer as Cura, or on a separate computer such as a Raspberry Pi) and use the OctoPrint connection plugin to connect it with Cura, and disable USB printing from Cura directly.
See? That's a useful piece of information. I thought someone would be interested in reviewing the log so I could assist further ending in, hopefully, an issue entry. Since it's "if it works, it works", I'm going to continue priming Cura with Printrun. I do many small prints. USB connection getting alive for me with Cura was a godsend. It saved me hours upon hours and is probably the only reason that printer hasn't ended up in a scrapheap yet 😄
Also, the issue is new. I've been using USB for the past 2-3 months. The issue started surfacing just this month.
ahoeben 1,951
Slashee_the_Cow 279
My mum wasn't interested in advice against using Windows XP on her computer after Microsoft stopped releasing security updates for it. I installed Linux despite her protestations (LMDE, because Cinnamon has a similar layout to Windows by default and the hand-me-down hardware is a bit old). And she got used to it reasonably quickly since she spends half her time in Chrome anyway.
Technology gets outmoded. USB printing in slicing programs is a relic of the days when printers had no brains of their own (not even enough to run a print off an SD card, and there's actually Marlin commands for doing exactly that thing) and had to be fed instructions line by line. Now, there's no good reason to do it unless you're doing it from a dedicated system (I have OctoPrint running on a Raspberry Pi) and plenty of reasons to not do it (cause prints getting interrupted when your computer freezes sucks).
