49 minutes ago, Slashee_the_Cow said:Well you could change the colour of the generic PLA 🙂. Unfortunately I don't know of any way to change the visibility of a cutting mesh like that.
Just changed the material display color to gray, good suggestion, thanks.
49 minutes ago, Slashee_the_Cow said:I've spent enough time around here to generally ignore the "why" and get to the "how" (if there is one).
As for messing up the regular fan speed height: I'll admit this is just speculation on my part (I don't greatly know the internals) but it makes CuraEngine treat whatever's in the cutting mesh as a completely separate mesh which messes with the initial layer fan speeds because it's reached the top of the first mesh so should be at full speed.
Makes sense. I'm sure I'll find a way to fix it one way or the other.
Thanks for your help.
Slashee_the_Cow 274
I'm not sure why you'd want an extra skin wall on the bottom (they're much more important to prevent the top lines sagging into the infill) but I've spent enough time around here to generally ignore the "why" and get to the "how" (if there is one).
As for messing up the regular fan speed height: I'll admit this is just speculation on my part (I don't greatly know the internals) but it makes CuraEngine treat whatever's in the cutting mesh as a completely separate mesh which messes with the initial layer fan speeds because it's reached the top of the first mesh so should be at full speed. You could open the gcode file and add your own M106 lines to control the fan speed, but that's annoying, especially if you have to do it a lot.
