Heck, because I have too much time on my hands... works in 4.13.1:
(It was this or downloading Cura 5.1... I only have so many different versions of Cura installed for testing at once)
So either the problem is your definition file is invalid (like I had to fix above, but that would prevent you from adding the printer at all and would warn you the profile is corrupt) or... ㄟ( ▔, ▔ )ㄏ
Slashee_the_Cow 269
You should put custom definitions, meshes, etc., in the Cura configuration folder so that they will be carried over to newer versions. Anything added to the Cura installation folder will just be ignored.
Works fine for me in 5.6.0 though:
Well, it did after I fixed your profile:
