GregValiant 1,255
"...there are so many factors and variables that are involved"
You said a mouthful there! Even something that seems simple, like changing from red to white, can require slightly different settings.
There was a poster on Reddit who attempted to build some sort of speed demon Ender. They were printing at 300mm/sec or something and the print looked like a pile of poop. They didn't have near enough cooling capability for what they were trying to do.
"Everything affects Everything" and "Every print needs it's own love". Patience and getting a slice just right will save more time than attempting to print at 1000. FDM is not a fast process.
Edited by GregValiant
Slashee_the_Cow 269
I'll get to the how (or at least my best guess at it) in a second, but first a warning:
You shouldn't. Only materials which are designed to be printed that fast, like high speed PLA, should be printed that fast. Most spools of filament will have details on the side of the idea printing settings for them, and I've found your average PLA tends to say about 65mm/s. If you're printing too fast the material won't have nearly enough time to set and it'll end up being dragged behind the nozzle (or just pulled out of position in general). It almost certainly will negatively affect your print results.
My Ender-3 V3 SE can print at up to 250mm/s and accelerate at up to 4000mm/s². Even printing at a slower speed, with the fan on full bore, sometimes the acceleration when it finishes a move and does a travel move can pull the filament with it resulting in the model being stretched out at that point. I never have the acceleration set to over 1000mm/s² to prevent this (and sometimes it ignore the values in the gcode file so I had to lower the maximums in the control panel of the printer).
Good quality print > fast print.
Okay, now if you're really sure you want to print as fast as possible:
And a couple of things to bear in mind if it's not increasing the F values in the gcode file:
If I may close with a screenshot from the page on Creality's website for your printer:
You're most likely doing typical printing yourself.
GregValiant 1,255
From the Ender 5 S1 definition file:
"speed_print": { "value": 80.0 },
From the Creality Base definition file:
"machine_max_feedrate_x": { "value": 200 },
"machine_max_feedrate_y": { "value": 200 },
"machine_max_feedrate_z": { "value": 35 },
"machine_max_feedrate_e": { "value": 50 },
"machine_max_acceleration_x": { "value": 2000 },
"machine_max_acceleration_y": { "value": 2000 },
"machine_max_acceleration_z": { "value": 100 },
"machine_max_acceleration_e": { "value": 5000 },
"machine_acceleration": { "value": 1000 },
None of that tells you what the actual Max Feedrates are in the printer. You need to send an M503 and view the response.
This is a snippet from the M503 response for my Ender 3 Pro.
echo:Maximum feedrates (units/s):
echo: M203 X200.00 Y200.00 Z45.00 E50.00
echo:Maximum Acceleration (units/s2):
echo: M201 X3000 Y3000 Z100 E1000
echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
echo: M204 P1000.00 R1000.00 T1000.00
echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_us> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z0.40 E5.00
The print speed comes into play on large models with a lot of straight lines. If a model is small or has fine details, the nozzle spends a lot of time accelerating and decelerating so the average speed (and consequently the print time) won't vary beyond a certain point.
Slashee_the_Cow 269
From the Creality website:
So the definition file should have an override for the max feed rate, but doesn't.
nealet 0
Thank you to both Slashee_the_Cow and GregValient. I sincerely appreciate the effort you went to with your answers and support. The tinkering and testing I have been doing, is showing that the best quality is coming from speeds way below the max and that there are so many factors and variables that are involved.
Thank you Again 🙂
