Hartelijk bedankt voor je antwoord
Al the settings are correct, just as above.
It can be the nozzle, I've had a overheating problem a few months ago. (Wiring problem, to much pressure on the cable)
But the weird part is that if printing at an angle the print will look better than the print of the UM2.
The machine is further in perfectly working order, this is the only thing that is bothering me.
3dcase 37
That does not look like a 100% infill indeed.
Are you sure your setting is at 100%? looks like 50
When using cura? it should be on the basic tab -> Fill density (%) 100.
Otherwise it is under-extrusion, In the bottom of the basic tab, check if flow is at 100% and the diameter around 2.85.
If that is correct, check/clean your nozzle and feeder.
