13 minutes ago, Slashee_the_Cow said:Make sure you have Walls > Minimum Wall Line Width set to a lower value than Quality > Line Width. Cura is capable of slicing different flow rates for different parts of the same layer while maintaining the same print speed.
Right now i have Quality > Line Width at 0.4 and Walls > Minimum Wall Line Width at 0.34
I can get it down to 0.2 but when i set it lower it throws some warnings and it doesn't change anything for the towers
It doesn't seem to want to recognize that it need to print the thin towers at a lower speed. I can see that at some layers it does different speeds for the same line types like here. there is a difference between the speed for the diameter test and the support test but the towers in the right left corner still print at the same speed as the bit chunk on the top
And as you can see the flow is the same throughout the layers
Edited by TheBolshe
Slashee_the_Cow 620
