Wire disconnected and bed crashed in extruder
Posted · Wire disconnected and bed crashed in extruder
Hello everyone,
I received my UM2 yesterday and when I was ready for bed-leveling, I followed the instructions on the LCD and the bed crashed on the extruder. I immediately turned off the printer and after I unscrewed the screw z to put the bed on the bottom. I tried again and the bed is still violently collided with extruder and bed was distorted by force. I am afraid of having damaged my printer .. I looked at the circuit and a connector there was disconnected! I do not know where it goes, I do not know what to do.
Few picture of the connection problem:
photo 1photo 2photo 3
I have not yet managed to make it work properly and I look forward to my first impression!
I hope someone can help me here,
Thank you in advance
Olivier Bourbonnais
    That wire isn't supposed to be connected to anything.
    The only wire relevant for bed positioning is the two black wires twisted together that goes to the z end stop - in your third picture. Is that properly connected?
    I presume you took the glass out from under the bed, and installed it on the bed. With the power off, you should be able to move the bed up and down by hand - do you see/hear the screw sticking out of the back of bed against the wall? That should trigger the end stop under the base. Do you hear it clicking when the bed gets to the bottom position? And unclicking when you raise the bed up a bit?
    o you think the crash can damage the printer ?
    Possible but unlikely. These printers are tough. More likely they will hurt you than themselves.
        • 28 replies
