Good morning Slashee, thank you for the response.
There is no cura.log in the 5.6 folder, only a cura.cfg file.
The 5.5 folder only has a cura.log.1 file
The 5.4 folder only has a cura.cfg file
There are no stderr.log files in any of the folders
Earlier versions (all the way back to 4.8) all contain the cura.log.1 files
I tried to attach the cura.log.1 file from 5.5 but it gets rejected.
I hope that this helps you to diagnose the problem.
Thank you
Slashee_the_Cow 272
If you could post the cura.log file from %APPDATA%\cura\5.6\ (as well as 5.5 and 5.4 if they were working fine) and if it's there, the stderr.log file from %APPDATA%\cura\ we can have a look to see if anything looks amiss.
