2 hours ago, flight-commander said:Thanks for trying.. appreciate it....bummer that not all STL files are created equally..
If you're running Windows, Microsoft's "3D Builder" app is actually really awesome at fixing errors in STL files. You just need to open it, click the tick in the top left, and there should be a popup in the bottom right saying it's invalid and click that to fix it. Then you can just save the fixed version.
Unfortunately I don't think it'll fix your problem here but it's good to know for in the future.
Edited by Slashee_the_Cow
DivingDuck 104
Looking to the attached model I think it was originally designed for a resin printer.
Meshtools indicate that the model isn't watertight. Sometimes it slices correct sometimes not. Repairing the Mesh did not help. It looks like the problem came from the model itself.
When I try to separate the models it came to a count of 579 single model fragments. I would suggest asking the designer of this model.
flight-commander 0
