Posted · Can't increase print speed while printing through Cura
Is there a way that I can increase the print speed of a project that I've already began printing or if I change print speed through the settings and reslice will it cancel or mess up my currently printing project? I am working with Ender 5 Plus if that makes any difference.
    If you reslice it you'd have to print it from the start again.
    There isn't an easy way to change the overall speed of a print currently in progress and the hard way (connecting it to a computer over USB then making a virtual serial connection to it then sending it some gcode commands) may not work - sometimes the printer won't respond while it's in the middle of a print, and even if it does, the only commands that would affect the speed will affect everything (including extrusion and travel) and likely ruin the quality of the print.
    • Heart 1
    That's the answer I had anticipated. It's not a big issue, it was more to see if I could print things with overhangs more quickly after they've passed over the area of overhang and were at a more stable point of printing. I appreciate the response.
