Bed Leveling Problem
finitfrog
Go to solution Solved by Slashee_the_Cow,
Posted · Bed Leveling Problem
Hello I have a Creality CR-10 V2  and when i level using the main control panel it levels wayyy different than it does when i level with cure but then i would use the cura auto home and I would level it a click print when it heats up and starts printing the little line that it make come out fine but then it tries to print about half a mm off the build plate and i don't know how to fix it please help 😞
    Posted (edited) · Bed Leveling Problem
    Yes i checked it the model is not hovering
    Edit: ( I watched it print closely and it will make the line and then proceed to go up about a mm and try to print from there causing it to be too far from the build plate and hardening before it can hit the plate and causing a failure)
    Edited by finitfrog
    • Solution
    Are you trying to print through Cura from your computer over USB? You should be printing straight from a memory card in the printer.
    USB printing in Cura is a legacy feature which is no longer supported and is a relic from the days when printers were too stupid to do anything but follow commands one at a time from a computer.
    I am USB printing because i have bought a new memory card due to the last one getting corrupted but when i put it in the slot it just slides in and doesn't read so i would give it a weak little pull to make sure its in and it just slides out and it doesn't detect it as connected. (i have tried making sure the card is valid and it is the right size i have a reader on my computer)
    Edit: I checked when I plug it in it does in fact click
    Edited by finitfrog
