If you have a model loaded into Cura, you can also right click on it and click Center Selected, which should work as long as you are using the correct profile for your printer in Cura.
If you loaded a .3mf file, those can contain positions of objects so they might not print in the centre for that reason. .stl files should always load in the centre of the build plate.
GregValiant 1,489
Welcome Nitin.
You did not mention what printer you have. Many printers have the "origin" at the left front corner. Some printers (mostly delta printers but one or two others) have the "origin" at the mid-point of the bed. The setting is "Origin at Center" and you can find it in "Manage Printers" and then "Machine Settings". While you are in the Machine Settings make sure that the build plate size is correct. The size determines where the mid-point is and so can effect the location of a print on the bed.
