59 minutes ago, Slashee_the_Cow said:For at least one of the objects, you're opening a gcode file, not an STL file. Cura can render gcode files for almost any printer but can't confirm whether it will work on yours, which is why the warning is there.
Okay, I understand what you're telling me, so I might need to convert the GCode back into an STL? (Can that even be done?) Because Cura doesn't even let me move the models around or modify them in any way.
Slashee_the_Cow 620
