Does the Cura mount method destroy SD cards under Linux?
Posted
· Does the Cura mount method destroy SD cards under Linux?
Could you please be more specific about "break"? I've never had any problems with saving to SD under Windows or Linux because Cura doesn't actually handle mounting the card or anything in either OS.
(Also if you could say what printer you have and what distro you're using that would help)
Slashee_the_Cow 276
