Cura tries to protect your printer against cold extrusion.
Cura tries to see if there is anything in your start gcode that heats up your extruder(s), and bed. If not, it will insert a heatup sequence on its own. Cura does not know about your PRINT_START macro.
Cura looks for the text "{material_print_temperature}", "{material_print_temperature_layer_0}", "{default_material_print_temperature}", "{material_initial_print_temperature}", "{material_final_print_temperature}" or "{material_standby_temperature}" in the start gcode to check if the start gcode contains extruder heating commands (so it does not actually care if you use M104 or M109 or not).
Cura looks for the text "{material_bed_temperature}" or "{material_bed_temperature_layer_0}" in the start gcode to check if the start gcode contains bed heating command (so it does not actually care if you use M140 or M190 or not).
As AHoeben explained...if there are Cura keywords in the startup then Cura itself doesn't have to include the temperature prepend lines.
For example: If your StartUp G-Code contained something like this:
M140 S{material_bed_temperature_layer_0}
M109 S150
PRINT_START
G0 F600 Z2.0
G0 F3600 X0 Y0
M109 S{material_print_temperature_layer_0}
Then the hot end would wait until it hit 150, then the "print_start" macro would run in the firmware, and then printhead would move up and off to a corner to ooze, and then the hot end would wait until it hit the "Initial Layer Print Temperature".
So it appears that at least one Voron model will accept temperature parameters as part of the "PRINT_START" macro.
So your homework assignment for today includes some light reading and a bit of detective work to see if your machine will accept any parameters for PRINT_START. (BTW The curly brackets are required for Cura keywords.)
1
1
ahoeben 2,047
The logic is here:
https://github.com/Ultimaker/Cura/blob/4.4/plugins/CuraEngineBackend/StartSliceJob.py#L428
GregValiant 1,492
M109 S150
PRINT_START
G0 F600 Z2.0
G0 F3600 X0 Y0
The Voron2 250 has this in the startup:
print_start EXTRUDER={material_print_temperature_layer_0} BED={material_bed_temperature_layer_0} CHAMBER={build_volume_temperature}
