Cura 5.7 linux (appimage) : some settings lost
Go to solution Solved by mediaklan,
Posted (edited) · Cura 5.7 linux (appimage) : some settings lost
Hi to you all !
I was trying out the beta 5.7 appimage (I was previously using 5.5) when I realized some settings were lost in the process, namely some generic custom profiles, and some of the materials I added myself.
# custom profiles :
# materials :
I can see in my .config/cura folder that I have directories related to each cura version (5.5, 5.6, 5.7). Is this why I've lost these settings between the 5.5 and 5.7 versions ?
What is the proper way to retrieve these settings please ?
Edited by mediaklan
    • Solution
    Wel, I think I've found out. The path with the settings I was looking for :
    /home/$USER/.local/share/cura/5.7/
    And in the /home/$USER/.local/share/cura/5.5/ folder, I've found the conf files that needs to be restore.
    Note : creating a folder with the same name as the appimage ending with .home or .config
    (e.g : ultimaker-cura-5.6.0-linux-x64.appimage.home) will get this specific folder to be used as /home or ~/.config for this appimage
    Closing this topic now.
    Edited by mediaklan
    Posted · Cura 5.7 linux (appimage) : some settings lost
    It's worth noting that at least for me Cura also has a config folder in ~/.config/cura with the main difference being that in the [metadata] section the files in ~/.config/cura have
    setting_version = 22
    and the ones in ~/.local/share/cura have
    setting_version = 23
    Both of these folders were migrated when I first launched 5.7. Hey @Dustin, what gives?
