hi again,
thanks for the really fast reply and test print!
And also good point at the horizontal elements, makes sense that you always need an angle because the printer cant put the PLA on nothing (printing in the air ). I will fix up these points and hopefully my printer arrives the next days.
thedudevt 0
faces in the model that form a 'ceiling' under an over hang should have at least a 20* angle from horizontal, otherwise you need to print with support which adds post process time and ruins surface finish. this would include the wall half way down the bore, and the arms going to the center pin.
Kyle
