Thank you. That works for the bottom layer which is most important to me.
It's not ideal for top layers of different shapes at different heights, but at least it gets the first layer correct.
I still think Top/Bottom Extruder not using the correct extruder for the walls is a bug.
Where would be the most proper place to report that as a bug or requested improvement?
GregValiant 1,258
Bring in a Support Blocker. Scale it and position it where it will affect the top layer. Set it to the extruder with the small nozzle. Make it 1 layer thick and when positioned correctly it should only affect the top layer.
In the "Per Model" settings set the blocker as a Cutting Mesh.
This is the top layer with a 0.2 nozzle.
This is the layer below with a 1.0 nozzle.
Here the blocker is only covering a portion of the top layer.
