But since I'm here, are there things I ought to know from ORCA before using it? As in setting I should or should not use in conjunction?
I am in the process of enabling LA in Marlin and then tuning it, just not quite there.
TYVM PDC
TYVM PDC
Can't help you with ORCA but there's an easy way to see what plugins you have installed - in the Marketplace, click the gear button at the top right, and it'll show you all the plugins you have installed (and then all the internal Cura plugins).
Embarrassing, meant to say CURA. Seems to me that once I've enabled LA in Marlin, I then come back to CURA and choose LA. Question is this: Are there other settings I need to deselect in CURA once I've chosen LA or will making that choice in CURA automatically deselect other settings that needn't / shouldn't be used when LA is being used?
Many thanks, PDC
Pridanc 2
OK, after restarting CURA the second time, I now see under Materials a box to use Linear Advance so...Never Mind!
TY y'all. PDC
