This is interesting and I shall check out this plugin. But it doesn't answer the question of what nozzle diameter actually does in the slicer. As far as I can tell, with the same line width and height, the same gcode will be generated even if you change nozzle size.
It does make sense that the nozzle size could be used to generate warnings. That seems reasonable enough. But if that's all it does, I think I'm not going to bother changing it. I've been more or less changing it out of superstition.
Edited by PCLoadPLA
Slashee_the_Cow 619
It affects the values which Cura will warn you about (the input box goes yellow) when they're too high or too low. It affects some values which are automatically calculated by default (though I can't remember which off the top of my head).
Fortunately for you there exists exactly what you want: open Marketplace at the top right and find the plugin "Printer Settings":
Now in the print settings menu, you can adjust not just nozzle diameter but a whole bunch of other stuff:
(there's more than that, just figured it'd be indicative to show you a section with six different nozzle settings in it)
Now you can make your nozzle size as arbitrary as you'd like! (up to three decimal places by the looks of it)
