A 0.1mm line width is incredibly hard to achieve on a 0.4mm nozzle. The general guideline is 60-150% of the nozzle diameter, which means 0.24-0.6mm for a 0.4mm nozzle. That will also make a 0.25mm thick pin impossible because because you can only print in multiples of the line width.
You also need to allow for tolerance: you can't print a pin the exact same size as the hole. It will be a literally impossibly tight squeeze. I usually have a tolerance of about 0.3mm to be able to put parts together.
Your acceleration rate is too high for precise work (it should probably be about 500mm/s²) and your jerk is far too high (should probably be about 4mm/s instead of 40). If these settings increase the print time significantly, remember: good print > fast print.
To have the best chances of printing something like this, you'd need a smaller nozzle. 0.2mm are fairly common. 0.1mm can be found but I've heard they're very hard to work with without just getting clogged.
But ultimately, I think the precision you're trying to pull off is just going to be literally impossible to achieve on any consumer grade FDM printer.
1
Slashee_the_Cow 271
